Diesel Forum - TheDieselStop.com - View Single Post - Sea Foam question.
Old 05-27-2009, 07:34 AM   #11 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
Yea I agree it is good stuff. I do everything that has a engine every year. The neighbors must always think that I have blown up an engine when ever I do it.
With the stroke I put it in a sprayer bottle and mist it into the engine, not flooding it out, but allowing it make its way through.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline   Reply With Quote
