Diesel Forum - TheDieselStop.com - View Single Post - E4OD goes to limp mode.
Old 05-28-2009, 07:32 PM   #2 (permalink)
chuckster57
chuckster57's Avatar
If the OD light is flashing then there should be a code stored. Your truck should be OBD I and you can either purchase a FORD OBD I code reader or using the link below, use an analog volt meter to obtain the codes. Then post back and we will see if we can help.
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
