I have been searching the old posts and am wondering about the relay more. When I got this truck it had a ton of shall we say improvised wiring for a plow, lights , sander etc. I went through and removed a bunch of butchery and I thought I was carefull not to just cut everything in sight. I tried to trace everything I removed back to the plow or till it terminated into thin air.
However there were some, I believe 3 relays that were taped together near the firewall D/s and they were just sitting on the inner fender loose. Also a couple of relays mounted on inner fender near D/S fire wall. It may be possible that i discarded the wrong relay. How and where would I ID the right relay and trace it back to the module or wharever it is supposed to go. I did leave the mounted ones and maybe 1 other in place. God only knows what they may have tapped into to get power and come to think of it this problem started just about the time I cleaned up the engine bay. If anyone has the schematic for a 93 F450 it would help.
