Diesel Forum - TheDieselStop.com - View Single Post - E4OD goes to limp mode.
Old 05-28-2009, 08:52 PM   #7 (permalink)
chuckster57
chuckster57's Avatar
Originally Posted by kolo View Post
I picked up the OB II scanner, just havent had time to read the directions and pull the codes.
Your truck is not OBD II...It will be OBD I . the Diagnostic link is under the hood, usually on the D/S near the firewall. If you look at the link I provided, it will show you a picture of the DLC. OBD II is usually under the dash and is a trapezoid shape.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
