Diesel Forum - TheDieselStop.com - View Single Post - MPG mandates?
Thread: MPG mandates?
Old 05-29-2009, 12:30 PM   #3 (permalink)
MarkEkberg
MarkEkberg's Avatar
My Photos: (13)
My wifes 06 Civic is rated at 41 mpg. While I can not get 41 I have been able to achieve 40 many times. In 1983 all the hp numbers were low, but the mpg were there.
The other thing is that the wonderful EPA has taken all that hp and turned it into emmisions. I wonder what an engine would pollute if they gave the manufacturers the ability to make a fuel efficiant engine without the epa over their shoulder?
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
