Diesel Forum - TheDieselStop.com - View Single Post - e350 tranny feals strange
Old 06-03-2009, 05:41 AM   #8 (permalink)
matsh
have not tested all settings on the tuner, only with stock, 80e and 100performance, i get more power on 80e so i usual use this or stock, it shifts smother on stock so if i am only driving in the small streets around here i use stock, but if i wot it will just gear up and then smoke alot and use long time to get speed. i think it would have been faster if it had used the gears better.
on 80e if i dont press max throttle just half way then it will run better thru the gears i think..
starting to get used to how it acts so it aint a big problem
1996 e350 7.3 powerstroke.
4" exhaust. custom intake. DP-tuner f5.
stage 1 diy injectors
tugger hd2 shift kit
tripple disc billet converter
matsh is offline   Reply With Quote
