Diesel Forum - TheDieselStop.com - View Single Post - Make Your Own: HPOP Line Removal Tool
Old 06-03-2009, 09:46 PM   #1 (permalink)
calico5string
calico5string's Avatar
My Photos: (14)
I posted this up a while back on another forum, and it recieved some positive response. So, I thought I'd post it up over here, too.
HEY MOD'S: Maybe you can make this a "sticky"?
There is a special tool to "correctly" remove the HPOP lines. The lines and fittings are made by Aeroquip and are called STC connectors (for "Snap To Connect).
You can remove them with a screw driver, but it's a pain-in-the-butt usually, and you take a chance of damaging the connector (hose-end).
I made my own tool after taking dimensions off of a "factory" STC tool. It's pretty straight-forward, if you have access to, and are able to do some simple metal fabrication.
Here is a sketch and a couple of pic's of the tool I made:
One thing I did not mention in the sketch is to go over the slotted area with a small file or emery cloth and debur all of the edges very good.
If you have access to a milling maching, you could also mill the slot (which is actually what I did on this tool), but the "hole & saw" method works quite well also.
Here's a little info on the Aeroquip STC connector.
Once the lines are off, you can remove the fitttings from the pump (and heads) and replace the o-rings. The pump side fittings use a -906 (that's a "dash 906" size) and the head fittings use a -905 size ring.
Once the fittings are installed back into the pump and/or heads, just snap the hoses back into the fittings.
It don't get much easier than that!
Enjoy!
Al in SoCal
2000 F350 SRW CC 4X4
AFE Stage II w/PG-7
Garrett 38R Turbo
Swamps Stage II Single-shots
Stealth Dual-HPOP
ITP Custom-modified Regulated-return Fuel System
DP-Tuner PCM & F-5 chip (Live tuned!)
Autometer Gauges (Pyro, Boost, Eng oil temp)
Non-EBPV Pedestal
AIH Delete
"T444e" Open CCV
4" Custom S/S Exhaust into 5" Dual Aussie Stacks
ZF 6-Spd "Hand-shaker"
Southbend Double-Disc clutch
...plus some other goodies...
calico5string is offline   Reply With Quote
