Diesel Forum - TheDieselStop.com - View Single Post - Testing MAP sensor, intermittant code P2036, wird result.
Old 06-05-2009, 01:22 AM   #9 (permalink)
mikeceli
UPDATE UPDATE
Yesterday I obtained the following voltage readings. engine off. metered air pressure "T" ed into MAP, PSI read w/ a auxilery boost gauge
3.9 volt at 11.5 psig should be 1.1 volt
4.4 volt at 14.7 psig " " 1.5 V
4.9 volt at 20 psig " " 2.2 V
referance voltage was correct at 5 volts
So the MAP sensor tests BAD.
NEW development....while driving 70 MPH, engine "hickuped" several times (instantanously lost power for a half second, several times). I then read codes an got a P0344 cam position sensor (problem).
Today I had Ford dealer replace the CPS (free under recall) and I installed a new Ford MAP sensor and cleared the codes.
I will test voltage w/ new MAP sensor and road test. After a few days, I'll report back.
God Bless America!
2000 Ford Excursion 4X4 PSD Limited
1986 Ford F250 4x4 Supercab, long bed , 6.9L/AT
2001 "MagneticRed" Corvette Coupe
1979 Pontiac Y84 "Bandit" Trans Am
1988 Lincoln Mark VII LSC
1996 Chevrolet Impala SS
1983 Chrysler Cordoba
1995 Buick Roadmaster Sedan
mikeceli is offline   Reply With Quote
