the cut-off for whether the ipr should have the edge filter is the 1995 1/2 year so kinda hard to say with a '95 truck. if you check out Blue Ridge Diesel: Diesel engines, diesel generatorsm, industrial diesel engines, diesel fuel injection and click on the alliant power link on the page it will give a parts listing for ipr valves and shows a serial number break number and also shows pictures of the valve with and without the edge valve so you should be able to tell which you took off your truck originally.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
