Diesel Forum - TheDieselStop.com - View Single Post - No power up hill towing, irratic boost gauge, poofing sound under hood? Stuck in PA.
Old 06-08-2009, 12:03 AM   #4 (permalink)
teamroper60
teamroper60's Avatar
I suspect your turbo vanes are sticking.... I had similar symptoms last summer when I knew my vanes were sticking... I cleaned the turbo and replaced the EBP..... Problem solved.... The newer flashes eliminate the EBP from the equation, so presuming you have a relatively new flash, you would not need to replace that...
pics
#43
SLAPS President and Webmaster
teamroper60 is offline   Reply With Quote
