Mon. I ran the truck hard (unloaded) up and down some hills for about twenty minutes. No issues. Then when I was just about to give up trying to reproduce the issue, boom, at 13 lbs. of boost, up a hill, it occured. Irratic idle, no power, puffing sound under the hood.
Tues. I changed the fuel filters. Last change was 12K ago.
Wed. I took it to a local repair shop.
The only thing they could find was the brake relay, just above the brake pedal was arching and the contacts were burnt and bad. They replaced that and couldn't find any other codes. They did the engine drive test at a stop, where they cycle the key, turn the steering wheel, press the brake, the engine rpms would go irratic then settle down, that test.
They said other than just start tearing into the engine, they didn't know what else to do.
I am heading out tomarrow, problem or not.
If anyone has any other ideas I would appreciate them.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
