Diesel Forum - TheDieselStop.com - View Single Post - pulsating brakes??
Old 06-10-2009, 05:33 PM   #2 (permalink)
BTBBT
My Photos: (19)
The problem is more than likely the fact that you turned your rotors. The rotors on these trucks just do not take kindly to being turned. Also, watch how you torque down your lug nuts as I've heard this can have an effect on rotors also.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
