Diesel Forum - TheDieselStop.com - View Single Post - F350 slide-in Truck Camper load capability
Old 06-12-2009, 12:30 PM   #7 (permalink)
SmokeyWren
SmokeyWren's Avatar
My Photos: (44)
Originally Posted by nitrogen View Post
as far as gvw of the op we can only guess because he didn't mention the year... load range E or the "new" equivelent are a must its not likely that his 315 are but once again without knowing brand and model he might as well not told us tire size either
He has 16" wheels, therefore he has a '99-'04 truck with a GVWR of 9,700 (CA emissions) or 9,900 (49-state emissions). Notice that your '05-up F-350 SRW doesn't have 16" wheels.
And he said his tires have a weight capacity of 3,190, but he probably meant 3,195, which is load range D in a tire size LT315/75R16.
Yes, the '05-up F-350s SRWs have a lot more weight capacity than the '99-'04. But you're still going to be overloaded over the GVWR of the truck if you load a 4,000-pound or heavier 11' camper on the typical CrewCab 4x4 PSD SRW longbed truck.
...with camper loaded wet i'm about 10600 ...
Including driver and passenger(s) and a full tank of diesel? If so, then you either don't have the typical CrewCab PSD 4x4 longbed truck, or else you don't have an 11' slide in.
SmokeyWren is offline   Reply With Quote
