Originally Posted by u2slow
Could even be 32-spline in the D60 full-float.
I believe that the change from 30 to 32 (D60) happened either for OR during 96. I had a LockRite in an 87 van and there was a heck of a lot of slop that put a lot of shock and wear and tear on the rest of the driveline. That causes a need for a lot of steering wheel movment unless you are going to drive like an old lady in the snow. If snow is the main issue then you WILL regret a LockRite. The same company makes a slightly more expensive and smoother model where you just change the spider gears also. They changed the name?????
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
