The one i got was clean inside. I did see a few areas that were poorly cast though that look like they could use a little cleaning up. My guess is they are trying to turn out as many as possible and that usually ends up meaning a drop in quality. I've seen it many times. It's a shame it has to happen that way. BTW I just got mine installed with the stock wheel and it's great. I love it.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
