Diesel Forum - TheDieselStop.com - View Single Post - Replacing the stock tank switch with aftermarket
Old 06-13-2009, 07:08 PM   #2 (permalink)
arthurgoboom
arthurgoboom's Avatar
I am using the stock tank selector valve for my WMO/diesel blend and haven't had any problems. I don't think the increased viscosity is an issue for the valve, especially if you are preheating the tank.
I don't believe preheating the diesel fuel will do any harm either. I have heard some rumors that heating diesel fuel actually helps have more complete combustion. I think most of the VO guys recommend heating to only about 150*F though, so you may want to consider thermostat control for your heaters.
I am not sure how well the VO will blend with diesel fuel either, someone who's using it will have to chime in with that information.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline   Reply With Quote
