Diesel Forum - TheDieselStop.com - View Single Post - Replacing the stock tank switch with aftermarket
Old 06-13-2009, 09:34 PM   #3 (permalink)
okiephillip
Been doing some reading on the subject. The Brits seem to run a 40% mix with no problems.
I took a 1.5 gallon glass jar an mixed a gallon of used canola oil with 1/2 gal of winter diesel then let it set for 24 hours with zero sign of the fluids separating. I plan to run 5 gallons of used canola oil to 12 gallons of diesel in the front tank. Was planning to only run the canola mix till motor is good a hot like while on the highway.
Added a gallon of used canola to about 10 gallons of diesel when I switched to the mix tank motor madeless noise but seemed to run fine. Will keep the group informed of my findings
Figure running a mix is a lot simpler than trying to run 100% canola.
Any thoughts?
White, 1996, F250, XLT, 4x4, 7.3 PSD, Garrett Turbo, Supercab, 8' bed, home made goosneck hitch, 257,876+ miles, Rotella T synthetic 5w-40, Motorcraft filters, BG synthetic trans fluid, two Haynes 1405 transmission fluid coolers.
okiephillip is offline   Reply With Quote
