Diesel Forum - TheDieselStop.com - View Single Post - No power up hill towing, irratic boost gauge, poofing sound under hood? Stuck in PA.
Old 06-14-2009, 07:15 PM   #22 (permalink)
EBX
EBX's Avatar
My Photos: (6)
Tech said the diesel tech was able to reproduce the issue 3 out of 4 times. Said possible oil pressure issue. HPOP?????? Injector control module????? I rented a Dodge Ram 2500 to get the 20' enclosed trailer and car back to Ohio. I'll drive back at the end of the week. Hopefully Ford can figure out how to fix what they sell.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
EBX is offline   Reply With Quote
