On mine, the housing with the stock wheel is much louder than even a WW was. I don't think I'll put the WW back on. I like it this way.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
