It sounds like you are saying that the 4 pin holes don't line up. 3 holes with a solid bar. If turning the mount over makes a difference, then it sounds like there is a slight misalignment (crooked holes) with both parts. A few minutes with a big rat tail file or power tools sometimes is the only way to make things fit. Fix the part that is the farthest from true. Then repaint. Don't overlook a possible bent pin.
