Diesel Forum - TheDieselStop.com - View Single Post - Another No Start
Old 06-17-2009, 11:01 PM   #1 (permalink)
1996250
Another No Start
I have a 96 that wont start. Ran fine no issues next day it wouldn't start. I have been reading on causes and made a list of things to check . The oil level is good. The HPOP is full. Installed new NAPA fuel filter and cleaned housing. Cleaned screen and checked fuel pressure at schreader valve(75PSI). Checked #22 fuse 10.7v while cranking not blown. Checked #9 fuse not blown. Turning the key on the CEL light flashes and the WTS lights for about 5 sec. There is no white smoke while cranking and no change when unplugging ICP. Batteries are 5 months old and fully charged (1000 CCA Each).The tach reads 200 rpm while cranking. The only code reader I have available wont read all codes, but shows codes 603, 606, 196. Is there something I missed that would be easy to check please let me know? How can I check the PCM and IDM? Any info or suggestions would be welcome. I have learned a lot about this truck on here. Thanks Tim
1996 4x4 Extcab XLT Auto,4.10 LS
Pyro,Trans,Boost gauges,Tymar Int
3.5 DP,Trans Cooler,LUK TC
1996250 is offline   Reply With Quote
