196 expected with a cold engine. 603 and 606 and flashing ce light are all possible pcm failures if battery connections and grounds are good. like said, check ipr nut and 12vdc at connector, koeo. If you have a chip, disconnect. Do you know anyone with a psd that will let you borrow their pcm?
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
