Diesel Forum - TheDieselStop.com - View Single Post - Another No Start
Old 06-19-2009, 12:37 PM   #9 (permalink)
action4478
If you use a guage ,,unhook one of the lines from the pump & attach the guage to the line note pressure ,,,
Then ..re attach the line to the head & do the same thing with the other head , note pressure
If need be , un hook lines to both heads ,attach the guage to one ,& cap the other ,,note pressure ,,this will dead head the pump itself & tell you if the IPR is stuck open (no pressure)
The other tests are mainly for injector o rings ,,may just need to verify IPR ,,if presure there , then move on to the heads ...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline   Reply With Quote
