Diesel Forum - TheDieselStop.com - View Single Post - New to diesels
Thread: New to diesels
Old 06-22-2009, 10:50 PM   #5 (permalink)
EBX
EBX's Avatar
My Photos: (6)
Read my signiture and my post about being stuck in PA. Can you still buy the Ford factory extended warranty?
It could be blow by on a loose turbo hose coupler. Maybe your turbo is starting to stick.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
EBX is offline   Reply With Quote
