Diesel Forum - TheDieselStop.com - View Single Post - antifreeze change
Old 06-25-2009, 10:08 PM   #6 (permalink)
chuckster57
chuckster57's Avatar
Originally Posted by Snotzalot View Post
Above the starter is a block drain, after draining the radiator, remove this plug to drain the engine.
I forgot that part of the change...was dealing with other projects at the same time. and now I have a Vacum pump with nasty sounding bearings...Oh well just MORE to do before we leave on Tues. I did undo the hose that comes from the bottom of the rad to the heater line. The drain thingy ( can't say it here) is broken off on the bottom of the rad.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
