Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 06-26-2009, 06:44 AM   #12 (permalink)
STurbo90
STurbo90's Avatar
My Photos: (9)
You may have a problem with the front cover,
You list '96 my, and I believe another member who had the same problem as you describe had found his de-airation valve had backed itself out.
If that happens it will bypass all the lube oil supply back into the pan.
I think the only way to verify is to remove the front cover, and I believe it was determined only 1996 my that had that style front cover.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline   Reply With Quote
