Diesel Forum - TheDieselStop.com - View Single Post - How much A/C oil?
Old 06-26-2009, 12:03 PM   #2 (permalink)
chuckster57
chuckster57's Avatar
AFTER flushing the system, My book says 7.00 oz. then there is an *
*On models with "authorized Modification" decal ( on radiator support near VECI label), add only the specified amount of refrigerant oil.On all models without this decal (except the following exceptions), add the specified amount plus an additional 2.00 oz. On 1993 through 1996 Bronco and F-Series Pick-ups without a decal, add the specified amount plus an additional 4.00 oz. If there is no decal on 1994.......
BASED on that I would think either 7.00 oz or 11.00 oz depending on the sticker. Best isto put 1/2 in the compressor and 1/2 in the drier/reciever.
Operating pressures:
LOW side 28-45
HIGH side 128-230
I would try to get the low side to about 35 and the high side to about 200.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
