Diesel Forum - TheDieselStop.com - View Single Post - water filter installation
Old 06-27-2009, 12:13 PM   #2 (permalink)
asauer
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
The factory setup has a water 'filter'- called a water seperator. I've never had any water come out of the bottom of the filters on trucks I've had for awhile, but a couple had water in the filter when I got them. Could have been from sitting for years.
So not quite sure on the effectiveness of the stock setup.
I'm sure if you dumped a measured amount of water in the tank, you'd never get the same amount in your water seperator- most of it probably makes it through.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline   Reply With Quote
