Diesel Forum - TheDieselStop.com - View Single Post - water filter installation
Old 06-27-2009, 12:38 PM   #5 (permalink)
asauer
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
Ahh I see. I figured you already knew what the water seperator was lol.
I know people on here have done it. It'd not entirely neccessary, but it would make keeping the SCAs at a consistent level easier (precharged filters) and it would surely keep the coolant a little cleaner.
I figure if the big rigs have them, they must be effective if you want to get lots of life out of the motor.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline   Reply With Quote
