Diesel Forum - TheDieselStop.com - View Single Post - Time to get a scanner (or comp. program) need suggestions
Old 06-28-2009, 08:15 PM   #4 (permalink)
ArrowHeadJim
Don't go with the edge programer. I like many on this site have had issues. My truck would not run after using it. I must say however that the company did help by sending a special programer to reprogram the original code. Which got me going again. The new replacement programmer did the same thing.
So... If you want to read codes get a tool for just that. I have one of the big orange ones from pep boys. Works fine for me.
There are units out there (expensive) which will allow you to perform tests such as buzz and contribution.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline   Reply With Quote
