On top of your rear differential. You'll see the pigtail plugged into it. If you're careful unplugging it you'll likely see water pour out of the connection or @ least be wet. It picks up road water thrown up there and leaks into the VSS, it's a common issue on the 06 for sure. Has one bolt that secures the hold down plate. I changed the connector and VSS. Taped it real good as to seal out water. No more ABS light and cruise doesn't kick off anymore.
Ken
2006,F-250 FX4,C/C,Lariat,6.0 PS w/ Auto& 3:73, Dark Satin Green/ Arizona Beige, Muffler Delete, Nitto Terra-Grapplers AT 33's
