Try a DIY exhaust brake, very cheap. Actually free if you have the few parts lying around. If you have an auto, you will need to also lock the torque converter at the same time.
I just bought the Hawk Pads and PowerSlot rotors. I've been waiting over a month for the rear parts as they are on backorder. No idea what's going on here.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
