Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 06-30-2009, 06:10 PM   #33 (permalink)
94strokerace
Originally Posted by rob-08 View Post
we verified that the lpop is bad over the weekend. but i bought my buddies truck for parts so i should just be able to swap them out... or am i oversimplifying it?
Sure, not a whole lot of work.
There are some air gap measurements you can take of the lpop. Lay the housing, with the gears inside, facing up. Place a straight edge, bridging from side to side, across the housing. If a .003 feeler gauge fits under the straight edge and the gears, its worn out.
This is good news actually.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline   Reply With Quote
