Diesel Forum - TheDieselStop.com - View Single Post - Need help with steering problem
Old 06-30-2009, 07:23 PM   #3 (permalink)
chassis
Check the (relatively) easy and (relatively) inexpensive things first:
- tie rod ends
- upper and lower ball joints
- drag link joints
Raise the vehicle on jack stands via the frame or suspension, so there is no load on the tires when you check these items. If any are loose, they can cause steering funnies.
If all are good, then suspect the hydraulic system. Check the fluid level in the reservoir. Then listen for steering pump noise while idling, and then listen for noise while turning the steering wheel from one full lock to the other. Do all this with the front tires off the ground. Last, check the pump and hoses for leaks. If any leaks, these need to be corrected with new lines or new pump or new gearbox seals. If any noises, fill reservoir to proper level and retest. If still noise, pump likely needs replacing.
In my experience, replacing a gearbox is very unusal. The input and sector shaft seals can be replaced in most cases.
2003 F-250 XLT CC SB 6.0L 6sp 2WD 3.73 open diff, cab lights, 6 disc, camper pkg, spare tire, sliding rr wdo, hitch rcvr, lighted TTT mirrors, security group, black/silver, ordered 12/17/02, built 2/13/03 13:56, delivered 2/19/03
2004 Cardinal T31BH travel trailer
1997 Lund 1700 Pro Sport, red over tan, 90HP Honda 4 stroke, 9.9HP Honda 4 stroke, 40 lb. Minn Kota bow mount
chassis is offline   Reply With Quote
