Replaced Turbo w/ Reman. Factory Turbo - Now 5 lbs. less Boost????????
The last Ford dlr. replaced my turbo at 63K w/ a remanufactured Ford turbo b/c they said my turbo was shot.
Out of warranty of course.
B/f the turbo change I would get 24 lbs. of boost at WOT since I bought the truck new.
Now, the max boost I can get at WOT is 19.5 lbs.
What gives? Did Ford tune down the turbos?
The X is 100% stock.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
