Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 06-30-2009, 09:31 PM   #35 (permalink)
JMCX
JMCX's Avatar
LPOP is behind the harmonic balancer. If it truly is worn out it doesn't speak well for how well your engine was maintained.
95's had a problem where the pick-up tube would crack up high and suck air instead of oil. That is why a previous poster suggested over-filling and jacking up the rear of the truck. This submerges the cracked part of the tube and will tell you is that is the problem.
Someone on here had a similar problem to yours and it was just loose bolts that hold the LPOP to the engine. Again, sucking air.
97 F350 SW CC 4X4 Auto, IDM mod, TW six position, DIY Stage I's, Beans D66 Turbo & 3" DP, 4" straight exhaust, Mobil 1 ATF, Tru-Cool 28k, Fuel filler mod, 99 Intercooler, Open Air Filter, SmittyBuilt stainless nerf bars, Trans-go tugger kit and Billet TC
04.5 Dodge 2500 QC 4X4 600 Cummins auto (work truck), 72 Mach I 552 stroker
JMCX is offline   Reply With Quote
