Diesel Forum - TheDieselStop.com - View Single Post - won't start and dealer can't find the problem
Old 07-01-2009, 03:26 PM   #7 (permalink)
OT
OT's Avatar
Blue..yeah, disturbing for sure. As mentioned, one possibility is HPOP leak listed here 6.0 PowerStroke bulletins You need to find out if tec. checked for hpop leak? It should be covered under p/t warr. Good luck!
btw..A classic play on words "If no
DTC found/set = could be "SOL until code shows"? Meantime..tsb says code may NOT be set. Definitely classic play on words.."Find another dealer/tech." JMO!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
