Diesel Forum - TheDieselStop.com - View Single Post - Truck runs but no accelerator
Old 07-01-2009, 04:37 PM   #8 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by Ro39 View Post
Not completely off topic and maybe a dumb question but could that be an issue with a manual transmission?
Not a dumb question at all.
The manual doesn't have that wiring in the column, so it wouldn't get broken and take out the instrument panel/IVS fuse.
That doesn't mean that the fuse blew for some other reason however. It's also possible that the IVS (Idle Validation Switch) went bad. It's there to prevent the engine from revving up unless someone has actually pushed on the go-pedal. If it fails, the PCM only lets the engine idle.
Hard or no-start? Check Here
