Diesel Forum - TheDieselStop.com - View Single Post - Oil leak, Valve cover gaskets? or something else?
Old 07-01-2009, 04:59 PM   #3 (permalink)
Oneof6
Also look up in the front of the engine down in the valley. If it is wet around the HPOP pump and in the front of the valley you could have a HPOP line weeping, it will get worse, oil that goes down in the valley and out the back through a drain hole, most of it will go down the passenger side over the starter and drip down where it LOOKS like a rear main crank seal leak but isn't.
Oneof6 is offline   Reply With Quote
