2001 F250 7.3 cranks, fires and dies. won't run
OK, I have gone through a lot of this forum and haven't found a problem quite like mine. I have an F250 7.3 4wd automatic. I have owned it since new. It has 130,000 miles on it and the only time it wouldn't start was a couple of years ago. I replaced the GPR and it fixed the problem. The truck has always run fine, it is not chipped, it's bone stock. A few days ago, I went to use it and it cranked over fine, popped off like usual and then immediately died. I tried starting it again and again with no luck. I will try to give as much info as possible because I know it's needed to troubleshoot properly. I was a certified mechanic myself over 30 years ago. Things have changed just a little bit since then. Anyway, I was really stumped because the truck has always been dependable. Then I got to thinking. I had it parked at the base of a 120' tower for my wind turbine. Later last week, a thunderstorm rolled through while I was gone, and my turbine took a lightning strike. I know this because when I got home later that night I had a diode blown out in the rectifier in the turbine controller. Also, I talked to my neighbor the next day and he told me he saw a big bolt hit my place. So, I figure that my truck got a tickle. (That'll learn me to park my truck so close to the tower) I did a little research on the net and then I got under the hood of the truck. First, I pulled the plug off of the ICP sensor on the driver's side cylinder head. I tried to start it and it ran but very erratic. I then pulled the plug off of the EOT on the back of the HPOP reservoir. I tried it again. This time it ran like normal. I took it for a drive of about 10 miles, no problems other then the SES light. I borrowed a Snap-on scanner from a friend a couple of days later and my brother showed me how to use it. When I first read the codes, it showed 7 codes. They were as follows: P1280, P0198, P0380, P0470, P1210, P1211, P0705. After clearing the codes and experimenting more, we decided that the ICP sensor was bad. I ordered one and put it on this afternoon. I reset the codes and tried to start it. I still have the same problem. Before I start buying more parts, I would like some input from someone more knowledgable and experienced than me.(it wouldn't take much) I went ahead and pulled the plug off of the EOT sensor and the truck started up fine and ran fine again. Still have the SES light and I noticed that the overdrive off light on the shifter was flashing when in park. If i put it in drive and wait a few seconds, it will stop flashing. When I put it back in park, it will start flashing again. I don't think that it used to do that. I checked the codes again after changing the ICP sensor and I got these codes: P0198, P0380, P0340, P0470, and P1210. With all of these codes coming up, I am beginning to believe that the PCM is messed up. I just don't particularly like the idea of just buying one without knowing that it will fix the problem. Any help or input would be greatly appreciated.
Jerry
2001 F250 Powerstroke
2006 Jeep Liberty CRD
2006 VW Jetta TDI RC2
2 Kubotas
Homebrew biodiesel
