BTW, the foil delete will have to wait, because from what hear around here, with the WW and the ATS, that thing screams......so I will wait because I don't want to over do it, I did put two Magnaflow mufflers after one was still "loud"...lololol.....so you can see that I am not into too much noise....but I will try to buy one w/o and leave mine alone, so that way I can swap it depending on my mood.
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
