Diesel Forum - TheDieselStop.com - View Single Post - Changing the fuel filters
Old 07-02-2009, 09:48 PM   #17 (permalink)
timid1
Originally Posted by 6.0-A-NO-NO View Post
I would not go past 5,000 on the oil change, fuel filters every 10,000....15000 max
You know your truck better than Ford does. After all, the manual does (not) state that you need to change your oil every 5k miles no matter what. Fuel filters is the same. I see three different answers in this thread and none of them match what the owner's manual says.
What it boils down to is that there is no "special" process. Drain the lower filter first by opening the valve. While the valve is open, unscrew your upper filter. Then unscrew your lower filter. Change your lower filter first then close the valve. Then change your upper filter. Badda bing.
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline   Reply With Quote
