Diesel Forum - TheDieselStop.com - View Single Post - Little 2 Prong Plug on the fuel bowl-Where does it go?
Old 07-02-2009, 10:36 PM   #5 (permalink)
777funk
Originally Posted by Patrick Feeley View Post
The plug would most likely be the one for the IPR (just to the left of the round thing (HPOP). Many folks forget to plug it back in (resulting in a no start). You shouldn't need to check the oil in the HPOP reservoir (the rectangular box-thing on the top front of the motor). Remove the plug on top to check the level. It is filled by the lube oil pump using engine oil. Some guys like to change it, but it's not really necessary either. Cheers!
Wow! So if that one plug gets a bad connection or the wire starts going south... any of us could have a no start mystery that we could spend weeks chasing down!
How many electrical connections like this are there on the Powerstroke?
So far I know of three now:
1. Camshaft Position Sensor
2. Injector Harness (Under Valve Cover Harness)
3. Now the Injection Pressure Regulator
Would a check engine code let me know which thing is unplugged on my van (95 Powerstroke Diesel)?
And... Lastly, what does the connection from the Fuel Bowl to the Injection Pressure Regulator do?
thanks!!
What I drive:
Ford E350 PSD 1995 --- Fast Diesel 385k Upgrades-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
MB 300d Turbo Diesel 1987 --- Fast and nice to work on
GMC Suburban 6.2 Detroit --- SLOOOW!!!
777funk is offline   Reply With Quote
