Old 07-02-2009, 11:10 PM   #1 (permalink)
ohiopsdx17
ohiopsdx17's Avatar
Rear axle makes growling sound.
Well lets start like this. This is my second rear end I have killed. The first the pinion bearings failed and made a mess and the one that replaced it was a factory 3.55 or watever it is with limited slip that had 80K on it. Now it Do drag race and run in pulls occasionally but just out of the blue the rear end started sounding like it had marbles in it at slow speeds and whines while driving. There was no metal shavings or any chipped teeth or abnormal wear. Is it possible for the pinion depth to change over time if I didn't touch the yoke or crush collar?? Could the back lash have come out of whack from abuse?? Im at a loss and don't want to start slinging parts I don't need.
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed. -4" Suspension Lift - 4" exhaust - 3" Downpipe - 5" Stacks - 10Kmod - Shimmed FPR - Home made air intake - Rosewood Stage 1's - TS 6pos Chip - Dana 60 Swap - 4:10 gears -
ohiopsdx17 is offline   Reply With Quote
