I just did this mod this week. It is the purple wire with yellow stripe. I cut mine where the harness comes down the frame under the drivers seat. I wired it with a three postion dptp swith (on-off center-on) so I can manually lock it, run with no lock up or normal, with light indications Be careful, there were two purple/orange stripe wires in my bundle. Make sure you cut the right one. After cutting, you want to ground the wire from the tranny to lock it up. Make sure you unlock it under 35-40 mph, especially before coming to a stop.
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
My Truck
