Diesel Forum - TheDieselStop.com - View Single Post - 7.3 Sounds a little funny when settling to idle then smooths out. Normal??
Old 07-03-2009, 11:39 AM   #2 (permalink)
PowerstrokeConverters
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
It is hard to diagnose via your description since it seems to be a normal thing, specially if it only takes "one second". If no other driveability issues arise, then you should just get used to the new sounds of the 7.3 PS. I am not sure if yours has a ExhaustBackpressureValve,EBV, that could be closed for a second to warm the engine faster, but I am only babbling here....welcome to the addictive world of Powerstroke Diesels!!
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline   Reply With Quote
