Diesel Forum - TheDieselStop.com - View Single Post - Bio-Diesel use in a 7.3 issues?
Old 07-03-2009, 12:43 PM   #13 (permalink)
okiephillip
Have a happy 4th July Y'all
My Canola oil experiment. I'm getting used Canola oil that spends about a month in a deep frier making french fries and onion rings. The cook does not uses hot water to flush out the deep frier so I don't have to seperate H2O.
Have added 4 1/2 gallons of filtered canola oil to the front tank's 12 gallons of diesel with no negative results yet. When running mix motor seems not as loud.
I start and shut off the the motor with the rear tank with 100% diesel. I do not switch over the the mix till the till the motor warms up and switches back to rear tank. I filter the canola into a large glass jar so I can see the oil. Do not plan to use canola oil in winter.
You tube has a bunch of videos of people runing older diesel motors on 100% vegi oil.
Check out myth busters on you tube.
Will keep forum posted on my results.
White, 1996, F250, XLT, 4x4, 7.3 PSD, Garrett Turbo, Supercab, 8' bed, home made goosneck hitch, 257,876+ miles, Rotella T synthetic 5w-40, Motorcraft filters, BG synthetic trans fluid, two Haynes 1405 transmission fluid coolers.
okiephillip is offline   Reply With Quote
