Diesel Forum - TheDieselStop.com - View Single Post - Oil leak, Valve cover gaskets? or something else?
Old 07-03-2009, 04:32 PM   #5 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Originally Posted by Todes View Post
I double checked last night and looked down the valley. It is more damp in the back left side of the valley if your looking from the front of the truck...Hope this helps.
Well, you're the one who will have to find the leak, as we kind of have trouble seeing it.
Where you're describing (under the turbo on the exhaust side) you have the EBP valve, which has an oil acutated piston that operates it in the turbo pedestal. That may be what's leaking. There's a kit available to rebuild the turbo pedestal Ford PN 2C3Z-9P466-AB or Int'l PN 1833815C93.
Hard or no-start? Check Here
