Diesel Forum - TheDieselStop.com - View Single Post - 1996 F350 dies - Help
Old 07-03-2009, 08:17 PM   #6 (permalink)
ArrowHeadJim
Did you try the removed parts in the donor truck?
Here's some information I picked up at dieselmans site.
Has some details on the ICP IPR diagnosis.
For no-start concerns check Injection Control Pressure (ICP) sensor readings with a scan tool or pressure gauge (500 min), or with DVOM at pins 87 to 91 (.83volt min) while cranking.
By using adapter fittings and plugs you can isolate and measure each cylinder bank to see if there is a high pressure oil leak in one head, or connect both HP oil pump hoses to the pressure gauge to measure pump pressure. NOTE: The 98.5 and later HP oil lines have special couplers requiring special tool 303-625 to disconnect, and tools 303-627 and 303-628 to connect to the coupler along with a pair of F4TZ-9N332-A elbow fittings to adapt to the HP oil gauge hose.
If isolated pump pressure is low, short break-out-box pin 83 to ground to run IPR valve to full duty-cycle. If the pressure comes up (3600 psi) replace the PCM; if it remains low, remove and inspect the IPR o-rings for damage; a kit is available if they are. If the IPR o-rings are undamaged, replace the IPR valve. If there is still low oil pressure, replace the HP oil pump.
If isolated HP oil pump pressure is 500 psi, or only one bank reads low, remove all the fuel injectors and replace their o-rings using the latest kits P/N F8TZ-9229-AA.
If the concern is a jerky, irratic idle when hot, unplug the ICP sensor (will set a code, causes the PCM to default to a pre-selected IPR duty cycle) to see if it the idle stabilizes. If it does, check the ICP voltage with a scan tool or breakout box at pins 87 to 91 with the sensor plugged in and the key on/engine off. It should be .20-.25 volts. If the base ICP voltage is within specs, replace the IPR; If not, replace the ICP and retest.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline   Reply With Quote
