Diesel Forum - TheDieselStop.com - View Single Post - DESPERATE!!! turns over with no start.
Old 07-03-2009, 09:20 PM   #47 (permalink)
ArrowHeadJim
Have you verified the lpop pressure is still not threre. If so, you might check the pressure releaf valve in the oil filter housing. If it were stuck open it would dump the oil back into the pan. With no or low oil pressure.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline   Reply With Quote
